Electric Training If you are new to electric learn more about them here or ask questions.
Twin motor hookup
Reply
Old 04-09-2011, 11:16 AM
alburman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Twin motor hookup
I am not new to RC, but relatively new to electric. All my planes from 1.20 I have converted to electric and everything above are gas powered. I am finishing up on a twin otter and have questions about wiring the esc's to the receiver.
1. I can wire both receiver plugs to a Y connector and to the receiver.
2. I can cut one of the red wires and then a Y connector to the receiver.
3. I can use two receivers and connect them seperately with left side ailerons and flaps on the left esc and the other side on the right side esc with the rudder and nose wheel steering also seperated.
4. I can cut both red wires and use a seperate flight battery pack.
Which would be the best way to go?
Thanks in advance for your knowledge.
Al Burman
alburman is offline
Old 04-10-2011, 05:39 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Twin motor hookup
It sounds as if you have a lot of servos... so you probably need either a separate Rx pack or an external UBEC... most in-built BECs are 3A or less, and so cannot run >3 servos.
Get a Castle 10A UBEC feeding the two Rxs through a Y-connector to the battery slot [disconnect the red wires on the Y'd servo leads from the ESCs to the throttle slot].
Dr Kiwi is offline
