Electric Training If you are new to electric learn more about them here or ask questions.
Slow Stick
Old 08-24-2003, 12:52 PM
Snowball1952
My Feedback: (22)
Default Slow Stick
I have a slow stick, but no paperwork on it. Do you know the CG. All I get it to do is porpus. Any Ideas?
Kevin
Again
Old 08-24-2003, 01:31 PM
sierra gold
Default Slow Stick
It should balance at a point about 4" back from the leading edge of the wing.
Old 08-24-2003, 04:02 PM
Snowball1952
My Feedback: (22)
Default Slow Stick
ok thanks how far back from the motor to the leading edge? all of it slides on the rod
thanks
Kevin
Old 08-24-2003, 05:02 PM
sierra gold
Default Slow Stick
I think the front(LE) wing support is about 5" in on the fuse. It doesn't make too much difference, as the CG is a point on the wing... not the fuse.
Old 08-24-2003, 06:14 PM
Snowball1952
My Feedback: (22)
Default ok THANKS
THANK YOU
Old 08-25-2003, 12:38 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default Slow Stick
Move the wing back and forth until it balances.
Old 08-25-2003, 12:57 PM
sierra gold
Default Slow Stick
Matt makes an excellent point... the SS is one of a few planes that allow you to adjust the wing position on the fuse.
If your SS is tail heavy, and most build out that way, slide the wing back on the fuse some. That increases the moment of the nose and decreases the tail moment. The weight of the motor will have a larger effect and help balance the plane w/o adding any extra weight.
Also, make sure your battery pack is as far forward as possible to help the balance.
Old 08-25-2003, 02:12 PM
Snowball1952
My Feedback: (22)
Default Slow Stick
thanks all I am greatful for the help!
We can close this now.
