Electric Training If you are new to electric learn more about them here or ask questions.
KMP 96 OV10 Bronco
Reply
Old 12-22-2011, 04:22 PM
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default KMP 96 OV10 Bronco
Hey guys, I am looking at converting an OV10 Bronco to electric. I know less than nothing about electics. My experience with electrics is a old 400 inrunner with a 1350 3cell lipo on a foamy that I haven't flown in years. (5 or more)
Plane has a 96"wingspan.
weighs around 28 to 32lbs.
It is a twin. with retracts
This plane flys good with 91 4 strokes or 20cc gas. It flys great with YS110s or 26cc gas. I would like to turn a 3 blade prop. Somewhere in the 14 to 15" range.
I would like to spend around the price of a DLE20 withall the trimmings. (batts, switches,fuel tanks ect.) I'm guessing $300 per side.
Now what do I need?
Kelly
Thunderbolt47 is offline
Old 12-22-2011, 07:11 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: KMP 96 OV10 Bronco
You will need (2) motors, (2) ESC's and you will have to decide if you want a single BIG battery or two large batteries, 1 per motor / ESC.
Here is calculator to run some numbers.
http://www.s4a.ch/eflight/motorcalc_e.htm
I ran the Tacon 110 with an 8s 6000mah battery and a 100 amp ESC
Motor
http://www.hobbypartz.com/96m607-big...325-295kv.html
ESC
http://www.hobbypartz.com/07e10-proton-100a.html
Battery
http://www.hobbypartz.com/98p-25c-5500-4s1p.html
You can set this up with a "Y" cable for 8s
Or you can run something like these
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
This setup will pull about 60 amps per motor, have 296 ounces of thrust spinning 16X10 props. That will give you around 37 pounds of thrust from both. So you should have about a 1 to 1 power to weight ratio.
Buzz.
blvdbuzzard is offline
Old 12-22-2011, 07:43 PM
Thunderbolt47
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Buzz, thanks for the info. It seem this is on the higher power side. (which I like) What kind of flight time could I expect. I know I wouldn't be flying full throttle with this setup would I?
Are ten minute flight time possible with this setup?
I was going to ask about the Hobby King stuff too. That sounds like a mixed bag of customer satisfaction.
Kelly
Old 12-23-2011, 05:44 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take a look at the chapter on selecting power systems as well as Amps/volts/watts
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
aeajr is offline
Old 12-23-2011, 05:59 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The calc program says about 10 minutes of mixed flying. When I was setting up my glider tug, it said I would get about 15 minutes of mixed flying. I have done over 30 minutes of touch and goes. I have found the results to be around plus or minus 10% or so. They are close, but hard to say until you set up a watt meter.
Buzz.
Old 12-23-2011, 09:23 PM
Thunderbolt47
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: aeajr
Yea, I read some of that until my eyes got crossed. I've got a lot to learn.[sm=spinnyeyes.gif] [sm=spinnyeyes.gif]
Kelly
Old 12-27-2011, 11:29 AM
Thunderbolt47
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: blvdbuzzard
Motor
ESC
Battery
You can set this up with a ''Y'' cable for 8s
Buzz.
Buzz, I notice that the ESC is rated for 2 to 6 cell. The batteries your are recomending are 8 cell. Will this work?
Old 12-27-2011, 08:49 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WHOOOOOOPS my bad
Here is the HV ESC
Sorry about that. Just cutting and pasting like a fool. They are more money, and the 100 amp is out of stock. You can also find them under a different brand at Hobby King.
80 amp
http://www.hobbypartz.com/07e37-proton-80a-hv.html
100 amp
http://www.hobbypartz.com/07e26-proton-100a-hv.html
Buzz.
