Electric Training If you are new to electric learn more about them here or ask questions.
WWI Props
Reply
Old 01-03-2013, 08:06 PM
BubbasanJohn
BubbasanJohn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default WWI Props
Hey Y'all. Im a newbie to electric flight. I just picked up a E-Flite Albatros Dva and I am looking for a wooden WWI style prop. Could not find anything specifically made for electric motors and I read somewhere that I could use a standard wooden prop. This is all well and good but would I have to go down a size in prop due to the added weight of the standard prop? What about the hole in the center. Im using a eflite 32 motor and itr has a 5mm shaft. Isnt this smaller than the holes that are drilled in standard props (the 14x7 size I need)?
Would appreciate any help you could offer!
Bubba
BubbasanJohn is offline
Old 01-04-2013, 06:53 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WWI Props
There are plenty of wooden 14x7 to choose from e.g. http://www.hobbylinc.com/htm/xoa/xoapjn14x7.htm, but for any of them, you'd need to drill out the hub bore to accommodate an 8mm collet-type or set-screw-type adapter (for 5mm motor shaft).
Dr Kiwi is offline
