Electric Training If you are new to electric learn more about them here or ask questions.
What is the difference between 6S1p and 6S?
Reply
Old 02-16-2013, 01:38 PM
cjtyped
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What is the difference between 6S1p and 6S?
New to electrics here. Also, what is the difference in discharge rates between a battery of 25C and one of 25-50C? Thank You in advance.
cjtyped is offline
Old 02-16-2013, 02:11 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: What is the difference between 6S1p and 6S?
In your title comparing a 6s to a 6s1p there is no difference since the absence of a "P" number means there is only 1.
For your discharge rate question there some missing text describing what the numbers mean , but commonly those types of numbers refer to a constant MAX rate and then a Burst MAX rate. If we assume that about the numbers then there's no difference there either since the absence of the second number probably coincides with the 50C on the first battery.
The 25C numbers are commonly referring to the constant MAX rate and are both 25.
guver is offline
Old 02-16-2013, 03:05 PM
cjtyped
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So, if I understand right, the C number tells me max continuous discharge, and the higher this number the better? You can't have a C number too large, but too small would be a bad thing?
cjtyped is offline
Old 02-16-2013, 04:53 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, you got it. Remember though that we are assuming what text is likely missing. The "C" number can also refer to charge rate , max charge rate , max discharge rate , burst rate , constant discharge rate, ect. In every case your conclusion is true in that you can't have one that's too high , but too small is a bad thing.
guver is offline
Old 02-18-2013, 09:06 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You multiply the C rating times the battery's capacity. This tells you how much energy the battery can safely 'dump'. A high C battery can dump a lot of energy at once, whereas a smaller C battery is for less demanding applications.
Example: 1000mah 50C battery: 1000mah x 50C c= 50,000ma, or 50A.
Example: 1000mah 25C battery: 1000mah x 25C = 25,000ma, or 25A
When you look at your system as a whole (motor, ESC, battery, prop) and determine how much current you expect to pull, you can decide on a C rating. If you are only going to run at 20A, you don't need the 50C battery.
Higher C batteries weigh more (and are more expensive). There is no need to get more C than you need, unless you just want that extra little bit of power.
Jetdesign is offline
Old 02-19-2013, 05:45 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Manufacturers C ratings can be inconsistent and, for lack of a better word, optimistic.
So if your calculations call for a realistic 25C then buying a 30 to 35c pack is probably a good idea, though a 50c pack would be overkill.
C rating is really the internal resistance of the battery, higher C packs can discharge faster without overheating and causing damage but as someone said, they are bigger and cost more.
BarracudaHockey is offline
Old 05-12-2013, 08:32 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
aeajr is offline
