Electric Training If you are new to electric learn more about them here or ask questions.
Hymax Motors
Reply
Old 07-02-2013, 04:53 PM
davidhand
davidhand's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hymax Motors
Would a Hymax CR3516 contra rotating motor be the equivalent 46 size glow engine?
davidhand is offline
Old 07-03-2013, 02:17 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hymax Motors
Perhaps. What are you trying to use it for?
The proper way to size a motor to an electric plane is by watts per pound. So if you have a plane that you expect to be 6 pounds all up flying weight then a 600 watt motor would give you 100 watts/pound.
More info with deeper explanations can be found here:
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
aeajr is offline
Old 07-03-2013, 09:43 PM
davidhand
davidhand's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the reference. I had in mind a pusher delta winged plane about 450 sqin wing area, 6lb weight. It seems I should be OK if I stay below 8lb. Ill use your reference again to select battery, ESC, prop etc. Thanks again.
Old 07-05-2013, 07:41 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are coming from the glow world, I would recommend you stay above 100 watts/pound as that is the kind of power set-up a glow guy would expect.  At 150 watts/pound most aircraft can hover
Electric slow fly can go down as low as 50 watts/pound and fly just fine.
aeajr is offline
Old 09-02-2013, 05:23 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.maxxprod.com/pdf/CR3516.pdf.... this document suggests that this motor is only the equivalent of a .30 engine. Reading the specs it seems that 35A/motor on 3s might be getting you 700W max. A decent .46 equates to around 900W.
Dr Kiwi is offline
