Electric Training If you are new to electric learn more about them here or ask questions.
Confused about correct ESC to Motor connection...
Reply
Old 07-28-2015, 01:58 PM
Mike001
Mike001's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Confused about correct ESC to Motor connection...
I'm building a SIG Kadet senior from the kit for my first plane and I'm making it electric. I have an eRC ESC and motor (motor is eRC .40 size and the ESC is a 65A) and I need help to ensure I connect them correctly. Three wires coming out of the motor are color coded- black, red, and blue- but the three plugs from the ESC are not color coded. There is a "-" sign on the body of the ESC next to one of the wires, but that's it.
I think the correct connection is motor black wire to the ESC plug with the "-". Motor red wire to the "top" ESC plug (matches the red "+" on the OTHER side of the ESC). And motor blue wire to the middle ESC plug. A pic is below.
Thanks for any advice.
Mike
Name:	ESC connection.jpg
ID:	2111530   Click image for larger version
Mike001 is offline
Old 07-28-2015, 03:37 PM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brushless motors run on AC not DC so there is no +,-. The three motor wires can connect to the three esc wires in any order. After you power-up and notice the motor running backwards you can simply swap two of the three connections to reverse the rotation. If the motor rotates correctly then leave the connections as-is.
Take a look through this when you can:
Everything you want to know about electric flight
flyinwalenda is offline
Old 08-22-2015, 12:21 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
How are you getting along with your new plane. Success?
aeajr is offline
