Electric Training If you are new to electric learn more about them here or ask questions.
Erratic Thumb on control
Reply
Old 11-08-2003, 10:29 PM
sofarcrashonly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Erratic Thumb on control
My thumb, the one that controls the right, left, up down is still untrained. Is there a add on for my Transmitter which will slow down my erractic thumb. I thought of adding a big piece of medium stiff foam around the control stick to dampen my movements and be a reminder that it takes small, gentle movements to direct the plane.
Nate
sofarcrashonly is offline
Old 11-09-2003, 10:18 AM
A1RENCH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Erratic Thumb on control
What do you mean by "untrained"? If you are overcontrolling, try reducing the control surface movement on the model. Also, check the center of gravity and try moving it forward just a little,
say a 1/16 or an 1/8 inch at a time to stabilize the model. Then fly in a wide open space. Trim the plane to fly straight and level. Practice flying HUGE circles, with very little control input. Next try some big figure eights, keeping both circles the same pattern. Point the plane where you want it to go, and let it go! Don't "muscle" it through maneuvers. Also, don't let the airplane get in a situation where you are panicking, trying to turn it or make it climb, because you will overcontrol it everytime! The most important thing you can do is fly! fly! fly! It takes a LOT of practice, and be patient with yourself.
Best wishes,
Bud
P.S. Remember if the plane is coming towards you, move the rudder or
aileron stick towards the low wing to level it out!
A1RENCH is offline
