Electric Training If you are new to electric learn more about them here or ask questions.
breaking in motor with gearbox
Reply
Old 12-29-2003, 07:13 PM
shams42
shams42's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default breaking in motor with gearbox
Hi all,
I got a GWS EPS 350C motor and gearbox to power my Dandy sport. I've read here that breaking in the motor in water can help it last longer and make more power. Should I do this with my motor? If so, is it okay to leave the gearbox attached or do I need to remove it somehow?
Matt
shams42 is offline
Old 12-29-2003, 07:59 PM
Mikerjf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: breaking in motor with gearbox
I use a lot of them and don't break them in. If you want to water break in putting the gearbox in won't hurt it, just dry it off after your done with a heat gun or hair dryer and put a drop of light oil in the bearings. If you don't want to drown the gearbox the motor's face mounted with two small phillips screws, remove them and pull the motor out. Retiming it's more beneficial than breaking it in, loads of info in here on retiming.
Mike
Mikerjf is offline
