can any one help with slow stick plaese
this is my 2nd plane im very new to rc planes 1st plane was a GWS P51 way to much for i never got it to fly now. i got the ss how doies this plane handle . when i turn how much rudder should i use. tks any tips on my 1st flight plaese help i will make sure CG is ok tks ANY 1
RE: can any one help with slow stick plaese
Gentle does it with the slow stick I have mine and love it. But even if you go full rudder it really doesnt hurt it just makes a tight turn. Make sure and put a prop saver on if its your first flight it might save your gearbox.
well the wind was pushing my plane not bad but it was moveing i tryed to take off and the plane tiped to the right on take off had to be the wind. so whats the wind speed shound be around to fly safe
TN
Less than 5 mph to start with. The SS is so big and light it WILL be blown around easily by any wind.
Cheers, Phil
Cheers, Phil
You can fly in 20mph winds if you really want just make sure that you are heading into the wind. If you are a beginner wait until it is dead calm before you fly this makes it much easier.
PA
Slow stick tips:
1. Apply pieces of tape underneath the wing center traveling several inches along the underside of each wing. This greatly reduces the stress on the wing dihedral aluminum tube connectors. I overstressed mine secewing around (constant turning, etc..) and watched one wing go straight up, and the plane straight down. The plane suffered little damage, and is flying again.
2. Your local hobby shop carries lighweight aluminum tubing that will slide directly over the original aluminum tubing size (they carry both sizes). This double reinforcement remedies the only weak spot which I have encountered in this plane.
Yeah I had the same pronlem with my wings folding. I went to the hobby shop and bought aluminum that fit the fiberglass rods and then some brass that fit over the aluminum. The other day I was flying in 10mph winds doing flips and I had no problem.
Matt
Matt
TN
Hi FockeWulf - can you find out the manufacturer and part number for that square section 10mm ID aluminum tubing? I've been hunting for that for months!
Cheers, Phil
Cheers, Phil
tks so much for tips im flying very good now. all most rdy to move on the slow stick is the best trainer i think i had 2 gws planes p51/easy.starter never could fly them hope i can now. going to buy new kits soon. any one ever had the gws b-2 bomber hows it fly???
