radio shack plane?
ON, CANADA
radio shack plane?
Hey everyone... I found this at radio shack and wanted to now what u all thoough:
http://www.radioshack.ca/estore/Prod...roduct=6018411
I think this is a great way to get into the hobby or help someone out. Can you think of any flaws that a cheaper airplane might have? Nothing that cant be fixed right? I say if it flys, then it cant be THAT bad. The price is right too at $100 CND. What do you think?
PA
RE: radio shack plane?
ORIGINAL: Urbanking
Problem 1: It is controlled by a single channel. How do you turn and go up at the same time???
Problem 2: Cox is not the best brand of airplanes you can buy cheaply. You can get a 2-Channel firebird outlaw for $50 USD
For a few bucks more, have a look at the Lazy Bee, at Hobby People (http://www.hobbypeople.net/home.asp)
They have it on sale for $120 at the moment, complete with a 3 channel radio, cobalt 400 motor, speed control, servos, and the complete ARF plane. All it needs is a good battery (probably another $30 or so) and it flies great. I put the cheapest battery on sale in mine, and get a short flight. It's a riot, and has throttle, elevator and rudder control.
Just my 2 cents worth,
Dave Olson
Dave Olson
ON, CANADA
it looks cheap because it is..
Anybody have experience with the firebird? I wouldnt mind getting a cheap electric to take on holidays, and help get people into the hobby or sumfin, as i fly nitro and my formosa is abit too big and fast. A small no hassle plane would be kool.
My Feedback: (9)
CA
I bought a COX plane - a different model. It was a 2 channel, throttle and rudder, twin engine. I could hardly keep it in the air - always wanted to turn right - the vert stab was warped. There was no trim adjustment on the transmitter - I finally threw it in the trash. I think you could do much better for the money!
IMO
IMO
PA
I have had experience with the firebird xl.(I think that they have replaced it with the firebird commander.) It has 2 channel control so it leaves something to be desired. To pull out of a dive you have to add more throttle. More throttle= more speed. So the ground will come up quicker[X(]. That to a beginner could be disastrous. Now to the other side of the argument. I think if there are only two channels the pilot will be less likely to panic.
Just my 2 cents
Just my 2 cents
ON, CANADA
deffinately... I would really rather something with 4 channels, but i may have to wait for a good 4 channel parkflyer to come around. I guess i will stick with the formosa for now.
I still have it, I don't know why. I think it's got about a dozen flights on it, and every time I had to charge the battery for 3 hours. Tried to sell it for $50 a couple times, no takers. It'll probably hang from my garage rafters until the rubber band breaks and the fuse falls to the concrete. I should pull the batteries out of the transmitter, before they leak... in fact, I think I'll go do that!
Good luck,
Dave Olson
CA
most times the cheapest aint the greatest, spend a little more and you'll get something better! I fly the sky scooter and it's great! 2 ch. and I heard the price has dropped to $60 US (unconfirmed)
