Servo trouble
Servo trouble
Could anyone shed some light on what may be happening with my radio gear please.
I'm setting up my new radio gear rec,servo's etc into a plane and when I switch everything on, one of the servo arms moves and the rest of the servos 'freeze' until the affected servo releases itself.
The setup I have is:
Hitec Flash5
Hitec 555 rec.
3 micro servos, throttle, rudder & elevator
All gear is brand new.
The order I am switching everything on is:
turn transmitter on (throttle to off)
plug batt into esc and switch on.
It is at that momment when I switch the esc on when the servo will move and freeze everything else. The time it takes to unfreeze itself varies, normally 20-30 seconds.
Any ideas greatly appreciated.
Hitec Flash5
Hitec 555 rec.
RE: Servo trouble
ORIGINAL: Flypaper 2
If you unplug the bum servo, does everything work all right? and which channel is the bum servo plugged into.? Try switching it with another channel.
ON, CANADA
RE: Servo trouble
ESC should be plugged into the throttle channel. Not sure which one it is on Hitec. You don't need a throttle servo. Motor plugs into ESC. Make sure there's no prop on the motor till you get everything set up properly for safety purposes.
RE: Servo trouble
Flypaper, sorry, I didn't explain myself properly. ESC is plugged into receiver on channel 3 as per instruction book. Instructions say to put rudder and elevator on Channel 2 + 4.
My Feedback: (21)
RE: Servo trouble
Make sure you didn't plug the servos in backwards. It's either that, or the servos are faulty. There are no adjustments or tweaks; it's plug-n-play. If it don't play, then something's broke and needs to be replaced.
This is a 3-channel plane? On a mode 2 transmitter (elevator and aileron on right stick), people typically put rudder and elevator on the same stick when there are no ailerons. That means channel 1 on the Hitec receiver for rudder.
