Electric Training If you are new to electric learn more about them here or ask questions.
Stryker help
Reply
Old 08-10-2005, 08:03 PM
OneLinez
OneLinez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Stryker help
Hey all. I'm new to the electric side of R/C planes! I have been flying gas for about 10 years. But electric seems to confuse me!?![&:] I have an F27 Stryker, and I love to fly it! The only problem is that the batteries do not last more than a few min. per charge. I have heard that using Lipo batteries are the best. I was just wondering how big of a battery I can use with it. And not to get onto another subject, I really want to get MORE speed out of it! Do I go brushless with Lipo? If so what is the best motor, and what prop would work the best? Any help! Thanks for any info!!!
OneLinez is offline
Old 08-10-2005, 09:32 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Stryker help
Hey, welcome to the club, welcome to RCU... Just plain WELCOME!
That's pretty typical of that plane, and of most planes powered by conventional "roundcells." The key is in mAh. The more mAh (milliAmp-Hours) a battery has, the longer the flight time. However, you need to be careful here. More mAh means more weight, unless of course you go LiPoly. LiPoly's advantage is that you can get 2-3 times as much mAh capacity in the same weight as NiMH.
What battery are you flying now?
Matt Kirsch is offline
Old 08-10-2005, 09:43 PM
OneLinez
OneLinez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the welcome! Well I have two batteries. One is a 7 cell Nimh 8.4v 900mAh, and the other is a 9 cell Nimh 10.8v 1000mAh. They both now don't work very well at all! I would like to convert to Lipo for the weight and power factor. Do I have to replace the factory speed control, and get a BEC?
OneLinez is offline
Old 08-11-2005, 04:40 AM
Glacier Girl
Glacier Girl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OneLinez,
Come on over to the parkflyers section of the forums, look for the F-27 Stryker, Way past the limits Part 3, section.
We can make you go weak in the knees. 100mph+ easy. [X(]
We have been building the DarkSide versions for a while now.
Also a good place for tips on making it better performance wise and how to make it last longer.
Everyone there is willing to help out.
Welcome to the Addiction.
Check out my gallery for some of my versions.
Glacier Girl is offline
Old 08-11-2005, 05:24 PM
timothy thompson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the stock batt and get 12-15min flights. use throttle management. Also are you letting the charger run until the led stops blinking rapidly. sounds like the cells are not getting a full charge. Lipros are better but you will burn out a brushed motor and need a new esc.
timothy thompson is offline
