Go Back  RCU Forums > Electric Aircraft Universe > Electric Training
Reload this Page >
Downthrust -- I need expert advise
Electric Training If you are new to electric learn more about them here or ask questions.
Old 08-19-2005, 07:16 PM
jmir
Default Downthrust -- I need expert advise
My elevator is in neutral position with the trim control in the middle position. If my airplane (J-3 Cub) wants to climb all of the time even when I try to trim it, is the problem:
1 - Too much downthrust?
2 - Not enough downthrust?
Will the answer change if my airplane has wings on the bottom, like a P51?
I'm getting conflicting advise on the subject from experienced pilots and I would like to know what the proper answer is.
Any help will be greatly appreciated.
Old 08-19-2005, 08:30 PM
Dr Kiwi
Default RE: Downthrust -- I need expert advise
Doesn't matter what wing configuration - in a tractor aircraft, 3 degrees downthrust and 3 degrees right thrust is typically used to mitigate the "nose up", and "torque effect" (left wing down) problems.
Old 08-20-2005, 10:10 AM
jmir
Dr Kiwi,
So, based on your comments, the answer to my question is No. 2 -- I don't have enough downthrust.
Is that correct?
Old 08-20-2005, 02:16 PM
pimaa
had the same problem with pelikan piper cub, axi 2212/26 i added 4-5 deg down and the problem was solved
