Electric Training If you are new to electric learn more about them here or ask questions.
gws receiver
Reply
Old 12-06-2005, 03:39 PM
wildjaych
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default gws receiver
I am not having much luck getting very much distance out of the GWS Naro 6 channel receiver. I can only get a couple of hundred feet from it and i can hear the motor sputter. I am using an Airtronics RD6000 transmitter that seems to be very nice. I am new to planes and started with a Slow Stick. I have had cars trucks and boats in the past and could get further than I can with this plane. Maybe it will go further but I am scared to try and lose it.
I read in one of these forums to try twisting the cables from the ESC, and servos but it didnt help. I checked the solder joint on the antenna wire coming off the receiver, looked good and strong. I cant move the servos and ESC further away to try to get rid of interference because the lines are too short. I dont know what else to try?????
I guess I will have to buy another receiver......I didnt want to spend much more money but I dont have much choice....Can anyone recommend one? good one for not much money???? let me know please.
wildjaych is offline
Old 12-11-2005, 09:20 AM
steve ypsi mi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: gws receiver
the 6 channel is rated at 1000 feet, we use the 4 channels and they are rated at 500 feet, we fly way past the 500 foot mark, more like 1000 to 1200 feet easy
If you are hearing motor sputter, we have a couple of planes that do that, never did figure out why but they still flew just that aggravating motor sputter
You might have the wrong shift, there are negitive which the futaba radio is and there is a positive shift for airtronics
GWS NARO RECEIVER 6 CHANNEL/J
[RECNARO6/J] $24.50
GWS R6N/J (Vertical Pin) - Positive
Weight: 7.8 g / 0.28 oz
Size: 20.0 mm X 30.0 mm X 9.5 mm / 0.79" X 1.18" X 0.37"
6 Channel GWS Naro Receiver for JR/Airtronics - Range: 300 meters/1000 feet
Then there is a negitive
GWS NARO RECEIVER 6 CHANNEL/F
[RECNARO6/F] $24.50
GWS R6N/F (Vertical Pin) - Negative
6 Channel GWS Naro Receiver for Futaba/Hitec - Range: 300 meters/1000 feet
My receviers have a little sticker that has a F on it for Futaba or Hitec
Yours should have a J on it I think to be the right rec
I believe that the crystals are the same for both
steve ypsi mi is offline
Old 12-11-2005, 03:28 PM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can't buy a better receiver for $39.99 than the [link=https://www.fmadirect.com/detail.htm?item=2098&section=1]M5 v2[/link] from FMA Direct. The 0.3oz 5-channel receiver has dual conversion design for glitch-free performance as far as the eye can see in the air.
Greg Covey is offline
Old 12-18-2005, 10:44 PM
john 8750
john 8750's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have two of the older M5's. They can't be beat, never a problem.
John Smith
john 8750 is offline
