Electric Training If you are new to electric learn more about them here or ask questions.
ESC help
Reply
Old 01-20-2006, 11:52 AM
beechpilot84
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ESC help
I have a GWS tigermoth that I have uprgraded with a 280 engine and an 7.4v 1600 mah poly battery. I was using the little ISC-50 speed controler for a long time before I hit the ground with the power on and it burned out. I bought the GWS GS-100 esc to replace the old one but it won't run the engine. The servos work fine but no power. I had the trottle trim set to the lowest position and tried all the steps on the box but it still won't work.
How do you match an ESC to the engine and battery?
Is the GS-100 not a good match for my application?
How can I get it to work?
beechpilot84 is offline
Old 01-20-2006, 06:55 PM
Bevo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESC help
Do you know for sure that your motor is good? Take your battery and plug it into your motor directly and see if power gets to it. In other words by pass the speedcontrol. If it does your throttle channel might be reversed. If no power gets to the motor your motor is bad.
Bevo
Bevo is offline
Old 01-21-2006, 05:02 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep! Bevo got it right!
aeajr is offline
