Go Back  RCU Forums > Electric Aircraft Universe > Electric Training
Reload this Page >
What is counterbalances & Cog
Electric Training If you are new to electric learn more about them here or ask questions.
Old 03-10-2006, 09:26 PM
Default What is counterbalances & Cog
Hi i have a newbie question. What is COG mean & what do people mean when they say --- Add counterbalances to the elevator---
what is that, what does it do.
Thank you.
Old 03-10-2006, 11:25 PM
jdetray
jdetray's Avatar
Default RE: What is counterbalances & Cog
COG = CG = Center of Gravity. This is the point where the plane balances, fore and aft.
A counterbalanced elevator is one where a portion of the elevator on either end extends forward of the hinge line. This provides a greater effective area for the elevator.
- Jeff
Old 03-11-2006, 09:43 AM
Scar
Scar's Avatar
Take a look at the reasons for adding balance area or weight to the elevator. One mentioned, extra area in front of the hinge, reduces the control load on the servo, at speed.
I always think of the situation where your plane drops into a rough landing. Picture the tail hitting the ground like a flyswatter. Then think what happens to the elevator - it slaps down after impact. Now think of the load that puts on your linkage and (more importantly) the servo gear. The way to keep from stripping a servo gear in that situation, is to keep the elevator from slapping down upon impact. The way to do that is to put balance weight ahead of the hinge. Then when the tail slaps down, the elevator - balanced around the hinge - won't deflect.
The same could apply to those barn-door ailerons, too. Good luck,
Dave Olson
Old 03-11-2006, 10:18 PM
Thank you for your replys, but im having trouble understanding the counterbalanced, do you have any pictures of the counterbalanced elevator.
Old 03-12-2006, 12:14 AM
jdetray
jdetray's Avatar
This diagram might help. The counterbalance portion of the elevator is the part that extends forward of the hinge. It is shown in light blue in the diagram.
- Jeff
Old 03-12-2006, 04:24 PM
Hi ,so basically the elevator is U shaped??? Is that correct.
is this picture correct
[link=http://members.aol.com:/burninhell5810/abc]picture[/link]
Old 03-12-2006, 06:03 PM
jdetray
jdetray's Avatar
Yes, you have it now!
- Jeff
Old 03-12-2006, 10:19 PM
Thank you all for helping out.
