Electric Training If you are new to electric learn more about them here or ask questions.
Best GWS-Slow Stick Battery location
Reply
Old 08-30-2006, 08:29 PM
EJWAY
EJWAY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best GWS-Slow Stick Battery location
Confused about where is best mounting location. Some go under wing other put infront of wing.
Someone tell me pro's and cons? I'm also seeing both Li=pos and NiMH type being used.
EJWAY is offline
Old 08-30-2006, 10:36 PM
Time Pilot
Time Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best GWS-Slow Stick Battery location
If you can manage the battery location at the CG, then you'll be able to swap out different packs of different weight without worrying about effecting the way the plane flys.
Time Pilot is offline
Old 08-31-2006, 12:13 PM
EJWAY
EJWAY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a logical solution for me. Thanks TP
EJWAY is offline
Old 09-02-2006, 05:32 PM
EJWAY
EJWAY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still not able to get CG at 4" before I add the battery at the CG. It seems that it stays tail heavy no matter where I locate wings and components. i'm using a 300 brushed stock motor mounted correctly. Note I'm trying to be able to mount Lipo 7.4 w/1300 mah at CG after I get the CG correct without battery. Any advice would be appreciated.
EJWAY is offline
Old 09-03-2006, 09:26 PM
pvflier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've built 2 and had to put the battery in front of the wing on both to get the correct cog....
pvflier is offline
