Do Prop Savers Save You Money?
Will using a prop saver save you money? Also will is cost you power and efficiency. Also not clear if you need one or two O-rings for proper use?
RE: Do Prop Savers Save You Money?
The whole purpose of a prop saver is to save you money. If it prevents even a couple of broken props or bent shafts, you've saved money.
As for the number of o-rings, common sense prevails. I use one o-ring on small motors, two of them on larger, more powerful motors.
Prop savers are not foolproof. You can still break a prop or bend a shaft -- I'm proof of that!
- Jeff
- Jeff
KY
ORIGINAL: jdetray
I don't like prop savers. I've come close to being hit by a prop that came flying off the prop-saver when the o-ring snapped. Most flyers go through three or four props before they get the hang of flying and langing. Then the props need to be replaced as they start to get nicks and chips on them. This happens whether or not you have a prop saver.
KY
I agree. I recently had one fly off during takeoff. I was lucky enough to notice what happened and quickly recover. After that happened I began using many very small rubber bands, similar to those they use to correct overbites with braces, instead of o-rings. This way there are many points of failure instead one one. The only problem is that I don't konw where I can buy them. Anyone know? There doesn't seem to be many uses for rubber bands that small.
