Go Back  RCU Forums > Electric Aircraft Universe > Electric Training
Reload this Page >
that motor and electrics
Electric Training If you are new to electric learn more about them here or ask questions.
Old 11-12-2006, 04:47 PM
hyperrockets
Default that motor and electrics
I wont to change a trainer that I have to electrics.
It is 6lbs with a wing span of 61 inch.
What motor should I use?
What ESC should I use??
What Battery should I use???
Thanks in advance
Don
Old 11-12-2006, 05:06 PM
Fliprob17
Fliprob17's Avatar
Default RE: that motor and electrics
Motor:
http://www.e-fliterc.com/Products/De...odID=EFLM4046A or http://www.e-fliterc.com/Products/De...odID=EFLM4032A Option 1 will have more power, just depends on what you want the plane to do?
ESC:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGVS3&P=0 or http://www2.towerhobbies.com/cgi-bin...?&I=LXMYN7&P=0
Battery:
http://www.cheapbatterypacks.com/tpl...id=TP4000-4S2P or http://www.cheapbatterypacks.com/tpl...id=TP4000-5S2P Again depending on power, the second battery choice has more voltage and therfore more overall power. The motor and ESC will handle either.
