Electric Training If you are new to electric learn more about them here or ask questions.
Shortened Slow Stick
Reply
Old 11-23-2006, 11:00 PM
spunkler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Shortened Slow Stick
Hello all,
I'm a newbie and just finished my 1st Slow Stick. I've read about shortening the fuse and did that , unintentionaly. I recived advice from a good friend about the build of my slow stick and built it without adding the tail piece of the fuse so I'm about 8" shorter than stock. (my friend didn't tell me to do this,I misinterpreted what he did tell me) I clipped the wing at the end rib, and am wondering if I need to relocate the CG. At this time it's at 4 1/8 ". Havn't flown it yet , but it's charged up and ready to go!! Thanks
spunkler is offline
Old 11-24-2006, 09:21 AM
Slo-V Flyer
Slo-V Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Shortened Slow Stick
I don't have that exact plane, but from experience I can tell you that is generally a safe bet to have the CG about 1/3 of the way in from the leading edge as a starting point. Try to fly it in no wind to figure out its behavior easily, as well as if you're just learning to fly.
When flying, if it wants to nose up too much/easily, move the wing back about 1/4 to 1/2 inch to move the CG forward. Or if it wants to nose down too easily, move the wing forward to adjust the CG rearward and keep the nose level.
Of course, how it stays level depends on how fast its flying, in addition to the elevator's trim and CG combined. I can set my Slo-V (similar plane) to fly at 40% throttle so that it's level hands-off, and noses upward under more power. Or I can set it to be nose heavy so that it doesn't keep pitching upward into the wind, but then I need to hold some elevator to keep from nosing down, and/or higher speed in order to stay level.
Slo-V Flyer is offline
Old 11-24-2006, 04:30 PM
spunkler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks slo v i'll give it a try
spunkler is offline
