nitro bi plane motor and esc
AR
have just ordered apollo 25 controller and ep10-10 motor will this fly 24 oz. plane it is the nitro ultimate bi-plane the battery is 11.5 volt with 8c discharge thanks for any help
KY
RE: nitro bi plane motor and esc
What is the capacity of the battery? I'm guessing it is LiPo, is that correct? Without it, I cannot determine the max amps the battery can provide. Also, you have a link to the motor? I cannot find the specs on it.
AR
the battery is 1500mh 3 cell the motor and controller come as pkg deal from tower hobbies it is listed under ultrafly motors thanks for response
AR
the battery is 1500 mh 3 cell li-po and the motor and esc come as pkg. deal from towerhobbies it islisted under uotrfly motors thanks for response
TX
Not to be rude, but I noticed you have two double posts so far in a row. Please don't double click the "SUBMIT" button, just click it once, *in case* that is what's causing the double post messages.
