ESC selection
ESC selection
i'm new to electrics and am looking for a speed control for my motor, it's an electrify t-600, 7.2v to 9.6v , looking for a good speed control, please tell me if more info is needed to help me
thanks, Austin
thanks, Austin
RE: ESC selection
Recently I was looking for the same thing. Several people recommended I go to http://www.raidentech.com/ekeshiqu20aa.html or http://www.raidentech.com/30aeshiquaie.html they have up to 50 amp if needed. Electrify's brushed esc is about $40.00 You'll find the above at about a third of that price.
lockman
When everything is coming your way, you're in the wrong lane.
lockman
RE: ESC selection
For a speed 600 you will want a 25 amp ESC. Depending on what battery and prop you are going to ue you might be able to use smaller but 25 should be adequate.
$35
http://www2.towerhobbies.com/cgi-bin...&I=LXKBF4&P=ML
$18 This is the ESC for the Spectra. Uses the same motor
http://www2.towerhobbies.com/cgi-bin...?&I=LXBNC5&P=7
If you are using 6 to 8 cells you will be fine. If you are using LIPO pack you will want an ESC that has a LVC that can be set for lipos. The first one can be set for Nixx or Lipo packs.
There are a number of GWS ESC on this page. Some for NiXX and some for Lipo use.
http://www2.towerhobbies.com/cgi-bin...S2=ESC&S3=&S4=
$35
