Beginner Slow Stick Setup Help
All,
I need help to set up a slow stick. I got the GWS Slow Stick from Tower Hobbies. Now I need to get the following.
Speed Control/Auto-cut-off
Battery
Charger
Radio
Servos
Misc. Items
Can you please post your setup?
Also I might have an eDVR camera mounted on it after few successful flights, so consider some extra weight.
I was thinking about getting Futaba 6EXA. Is this good enough?
http://www2.towerhobbies.com/cgi-bin...=LXKAJ1**&P=ML
Battery
Charger
Radio
Servos
Misc. Items
RE: Beginner Slow Stick Setup Help
ORIGINAL: egens
Is this your first plane? I would recommend different set-ups for someone who can fly and someone who can't.
My first SS had:
Speed Control/Auto-cut-off: GWS ICS 300 speed control
Battery: 8.4V 650mAh nimh
Charger: Hobbico MK II
Servos: 2 Hitec 55's
Stock Speed 300, D gearing, 11x8 prop
GWS Naro 4 Channel Rx
Speed control: electrifly c-12
Battery:1200 6 cell Nimh
charger: piranha peak charger
servos: ones that came with radio which are futaba 3111's
Motor:speed 400 11x6 prop
Receiver: futaba ultra micro reciever
Radio: Futaba 4exas
great setup around $200
Radio: Futaba 4exas
