lipo battery questions
I had a 3 cell 11.1v 1320mah pack... the positive tab broke off on one of the cells... but from what I can tell the other 2 tabs are still in perfect condition with tabs still attached.... How would I wire these up.. and would the mah be the same?... and im assuming it would be a 7.4v 2 cell...??
RE: lipo battery questions
you can also check out a tool like this that shows where the balancing taps hook up. It's the same as jdetray posted though =)
http://www.commonsenserc.com/page.ph...po_wiring.html
