Alnything about SUPER CUB....
IN
hey, guys i'l start this thread to gather any info. bout super cub to be helpful to noob just like me..
i just got this, my very 1st trainer airplane,,but i broke the props already,,,can i use any 10x8 prop?
ON, CANADA
RE: Alnything about SUPER CUB....
Super Cub uses a 10x8 Prop, this the same prop that is used on the Parkzone P-51, FW 190. They are Cheap and usally in stock at your LSH. Buy a couple if you like landing on grass feild.
Great Flying Plane Have FUN!!
MO
yeah i found you save props at first if you just take off the wheels and wheel pants and land in grass. you just cut the motor right before touchdown. this way it sorta flops onto the grass but its controlled. if you leave the wheel stuff on then she likes to cartwheel. oh yeah and im trying to get this tip out: pop off the motor cowling and loosen up the motor mount so you can put a rubber band around the motor and the mount. the motor torques the mount sometimes when you cut the power and it is especially helpful when the plane wrecks because if the mount breaks then the whole assembly isnt wheeling about under the cowling.
oh and nerf guns help get the planes out of trees without causing much damage.
IN
thanks guys, just got new props[sm=thumbup.gif]...
CoytAW,
please elaborate ur tips bout putting rubber band around the motor...
well, got another crash[:@], while preparing to land wind blows and plane suddenly drop hit the ground nose first, then put a dent in the motor, cut the wire then motor wont turn freely,,any[sm=idea.gif] idea of quick fix,or any good motor upgrade?
CoytAW,
