CP Pro gone wacky
CP Pro gone wacky
I have a Blade Cp Pro and when I hook up the battery the main motor will spin at high speed without moving the throttle. The 3 in 1 flashes mostly red but once in awhile green. After battery is plugged in for less than a minute the motor will come on. Please help!! I suspect the reciever but as a newbie I am looking for help.
FL
RE: CP Pro gone wacky
Is your Throttle Trim all the way Down too ?
Do you have a Gyro ? Does the 3 n 1 initalize
properly ? It should stay solid green.
Is the Idle Up switch in the proper position
when you start (toward the back) ?
Bob
