Just purchased a supercub
Looks like a great site. I hope to learn alot from it. I got a Supercub last month. Ive had my share of crashes. Im getting the hang of it and now all my crashes are from trying to fly low over the ground or tricks. Im getting a little bored with it. Can I put a larger batt to speed things up? Im running a 9.6v 8 cell 100mah batt. Can the prop be changed as well? Thanks
RE: Just purchased a supercub
I've tried a lot of different mods to the Super Cub. (I own 4) So far the one I'm most happy with is just a stock plane with a rhino 1350mh 3cell lipo ($20 from Hobbycity.com). You will be amazed at the speed and climbing performance. You will have to add a dean's connector to the plane, or add a hobbyzone connector to the battery, or do what I did. I made an adapter by taking a connector from a bad Super Cub nicad and soldiering it to male deans connector. This way I can still use the stock battery if I want to. You will also have to trim the inside of the battery box a little, but it is worth it!!!!!
