mixing servos
MO
mixing servos
UH at the risk , and hope, of not sounding to dumb on the F22 raptor buy FIY ( fly it yourself) there are only two servos and these four servos are connected to the aler and the elev both. Long wire on both sides connects to aler and the elv. Do I set up the transmitter as a delta wing (on the JR 7202) or do some sort of mixing so that both the alerion and elevators work correctly? I am thinking that when I give it a little up elev that all of the alerions and elevators should move to the up position. Right ?? And when I give it an alerion comand (either left or right ) then that sides elev and aler should move together and the other remain still right . I know I knew this once but where the memory of just what to do to set it up has vanished from my dwindling brain . Any one want to help the old guy out with this one once again
PA
RE: mixing servos
ORIGINAL: dancingeagle
...there are only two servos and these four servos are connected to the aler and the elev both...
How about a photos of what you have?
