RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Electric Training (http://www.rcuniverse.com/forum/electric-training-102/)
-   -   Binding (http://www.rcuniverse.com/forum/electric-training-102/11228001-binding.html)
tangy 09-13-2012 09:51 PM
Binding
Hi all
have just got a Rtf f6f hellcat. I have noticed that there are 4 wires inside the cab. Obviously two are for ailerons, 2 for elevator. Yet my receicer only has one allocated spot each for these. Do i need to get Connectors/joiners??Also, since the plane was basically made up, the elevators seem to control the rudders. There is no wire that i can see to independanly control this.
using a FMS 4 channel 2.4ghz trans, with a fhss 2.4 receiver(xy-5) .
Any help, suggestions would be Great.
Thankjs
Jake.<br type="_moz" />
Glacier Girl 09-14-2012 10:00 AM
RE: Binding
2 for aileron, ONE for elevator, ONE for rudder.
Ailerons would go on a Y cable. Just like it sounds, cable looks like a Y. Plug each aileron servo lead into the short legs of the Y, the long leg goes to your rx.
On most systems, other then JR/Spektrum, ailerons go to #1 slot on the rx, elevator to #2, motor/esc to #3, and rudder to #4.
Almost sounds like you have the rudder plugged into the aileron channel.The ailerons and elevator are on the same stick, rudder and throttle on the opposite one.
Landshark67 09-14-2012 04:57 PM
RE: Binding
Did you buy this new?  A RTF plane should already include the Y harness for the ailerons if one is needed.  If it's not there, contact the place where you bought it and let them know it was missing.
aeajr 09-19-2012 06:36 PM
RE: Binding
If it is RTF there should be nothing for you to do but tune it.
<div style="FONT-FAMILY: 'Arial'; COLOR: #000000; FONT-SIZE: 10pt">&gt; THINGS TO CHECK ON AN RTF</div><div style="FONT-FAMILY: 'Arial'; COLOR: #000000; FONT-SIZE: 10pt">&gt; http://www.rcuniverse.com/forum/m_6582895/tm.htm
</div>
highflightmat28 11-04-2012 06:51 PM
RE: Binding
What are the steps to binding a Futaba 10c with a  Orange RX Fasst 8ch
aeajr 11-04-2012 07:34 PM
RE: Binding
Same as binding a Futaba FASST receiver.
