Select Motor for a Carl Goldberg Tiger 2 Kit build
Hi folks,
I need some help with picking motor/ESC/battery for a 80% done kit build Tiger 2 (a low wing trainer, weighs about 5lb) I have zero experience with electric motors, after read articles like this one http://www.flyrc.com/glow-to-electri...n-tips-part-i/ and a couple of forum posts on converting glow powered Tiger 2, I have narrowed my range of motors to following: max watt: 1200-1400w max current: 30-45A Kv: 500-800 however it seems to be difficult to find a motor that 1) fit the specs above 2) in stock 3) ~ $60. The closest thing I can find is Turnigy Aerodrive SK3 - 4250-410kv Brushless Outrunner Motor ($37) But it's kv value seems to be low (410kv) Would this actually work? I will do some basic aerobatics but nothing too crazy. Longer fly time would be nice. The article above also mentioned a couple of motors but they are all pretty expensive, the least expensive one is Cheetah A4120-7 Brushless Outrunner Motor ($64) How does this compare to Turnigy one? Thank you! -Xiaotian |
How did your build come out?
