Help me diagnose my problem!
Hello,
I have been having a plauge of problems with my Beam E4. This is particularly annoying because all parts are mail order, otherwise I love this heli. The hell itself is rock solid and very responsive. First the setup. Beam E4 airframe Futaba 8U Heli Radio with Spectrum 2.4 conversion pack Spectrum AR6200 2.4G receiver Hitec HS-65MG servos for cyclic control. Futaba GY401 and matched S9257 digital servo for tail control Scorpion HKII-2221-8 Brushless Outrunner Scorpion Commander 45A ESC Batteries are 2200mah 4 cell Lipos Here is the problem. Everytime I have tried this heli I crash it. The radio will lock out on me for some reason, it will continue to fly until it hits something. This is not safe, or cheap, I need to figure it out. I switched from FM to 2.4 radio system. I replaced the servos. I adjusted my throttle curve to a 80% max. The last flight I didn't go above hover throttle. I checked my timer and it was at 2:30 left, I think at about 2 min it did the lockout and crashed. My voltmeter is at work so I can't check the battery level but I don't see it using that much. My hobby shop recommended the 4 cell battery. Is this wrong? I have not checked the head speed but it sounded reasonable. Let me know anymore info you need, I fly the crap out of my Raptor 50 with no problems and thought an electric would be convenient but all it has been is a pain in my side! |
I tested the battery this morning at work, with no load it is still at 15v
Is is a lock out or a brown out? Are you using a BEC or the built in one for the ESC? If you are using the built in BEC, it might not be enough to handle the draw of what you have.
Easy test, use a separate 4or 5 cell flight battery for the Rx. Just remove the red wire from the ESC to the Rx. Buzz. |
Thanks for the idea, I will look into it. I have to wait for repair parts before I can really test it out.
From research it sound like it probably is a brown out, however I didn't realize the Beam helix were so old already and will have to source parts and fit them appropriately before i can test.
Yeah they go out of production pretty fast or the time just flies by because we are having so much fun?
Buzz. |
