SS throttle question
Can I fly my SS at 1/2 throttle and still be able to maneuver it well? At what point would I reduce the throttle? (I assume it has to be at full throttle to take off...even with a hand launch?)
Thanks for the help |
RE: SS throttle question
In the Kiwi vernacular, the only thing to do is "suck it and see!" EVERY SS is different so there are no hard and fast rules - you just have to try it out.
Cheers, Phil |
My SS will take off in about 20' and climb out very scale like at 1/3 throttle.
" scale like " can that be used in the same sentence with the SS? But you know what I mean. It depends on the battery, motor, prop, ground, weather, CG. |
My SS will not take off from a hand launch at 1/2 throttle. Trial and error....now I know!
