PCM radio
Just what is PCM capable?
RE: PCM radio
There are two primary command systems that are used on 72 mhz FM radios in North America. The most commonly used is FM/PPM, usually refered to as FM. The other is FM/PCM which adds a few features. Both are FM.
Some radios can transmit on FM/PPM and some on both. Receivers are usually either FM/PPM or FM/PCM capeable. How did I do? |
