Battery ????
I have a Hobbico Superstar EP and would like to run my sons 7.2V 3800 batteries instead of the 8.4 2100 batteries, I figure it would reduce some weight and get me better run time will this work?
RE: Battery ????
Yes, the battery should work fine however you will probably have to go to a larger diameter propeller since you are dropping your volts down.
Bevo |
RE: Battery ????
Thanks;)
