Rx/Tx and air/ground Questions
Hey guys,
I've got a few questions, 1. Can air RX/TX work on ground? 2. If so would it have any problem working underwater? 3.Is the Hitec Laser4 transmitter an air or ground transmitter and will it work with a HFS-04mg reciever? (you can find the parts at [link=http://www.servocity.com]www.servocity.com[/link].) Thankz, _____________________ Uh-Oh,Incoming! |
RE: Rx/Tx and air/ground Questions
1. yes a air Tx/Rx will operate on ground- such as landing/take off. A good example of longer times on the ground/and water is the hydro boats.
2. Do you mean as in a sub?- not sure maybe someone else could answer. If plane/hydro tips or crashes it may damage the electrionics. 3. yes the Laser4 and the HFS-04 will work together as long as they are the same channel. Also the Laser 4 is an air Tx and not meant to be used for ground. |
