I'm in
I got a FireBird II Yest tur day and Love it Got N E tip"s? and Mod"s :D
I'm in
I flys nice stock but it is a lot funner with a 5 cell battery instead of the 4 cell pack. I had some loose 270 mah batteries and made a couple of 5 cell packs and had a lot better climb rate and power. Plus it handels a bit more wind with the extra cell. Check the control wire about every time you fly because they seem to like to work there way loose.
For a little better turning add a 1/2" of foam to the controls on the tail. The bigger surface give a little better control. |
I'm in
Thank you for the reply :D
I'm in
i did the /add a 1/2" of foam to the controls on the tail. The bigger surface give a little better control/ haven't tested it
