Hobby Zone Super Cub prep
Does anyone recommend using packing tape to reinforce the leading edge of the wings on a Super Cub? Thanks in advance R</p> |
RE: Hobby Zone Super Cub prep
Yes 100% Positivly Absolutly, I would also add some on the side of the fuselage at the tail.
Thanks for the info. I will be certain to do that. I am hoping to maiden my SC this afternoon!!
Rick |
Certainly won't hurt as long as you don't pile it on. One layer is all you need. Just make sure it is well stuck and smooth. No wrinkles.</p> |
I also found out (the hard way) that it's important to put packing tape on the inside of the cowl. That way if you nose in, it's not an explosion of plastic cowling. Looks a bit dramatic and a tad disheartening too.
ORIGINAL: russ_hillis I also found out (the hard way) that it's important to put packing tape on the inside of the cowl. That way if you nose in, it's not an explosion of plastic cowling. Looks a bit dramatic and a tad disheartening too. |
