Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
MQ-9 Reaper help / advice
Reply
Old 01-26-2011, 05:02 PM
jhop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MQ-9 Reaper help / advice
hey guys i just got a MQ-9 reaper from nitro plane and im going to put a nitro motor inplace of the electric one. I put one of my really old .20 engines where i wanna put it but does anyone know if someone makes a shaft extension or something that would work for my problem? I really dont wanna mount the engine all the way in the back because of the weight and i dont really wanna cut into the top. also does anyone know what size engine i should use?
I have alot of other questions but lets start here and see where it goes
jhop is offline
Old 01-26-2011, 05:07 PM
jhop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MQ-9 Reaper help / advice
BTW its about 4 1/2 inches from where u mount the prop on the engine to where it has to exit the back
jhop is offline
Old 01-27-2011, 09:04 AM
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool project!
I don't know if there is a commercially made off the shelf extension that would be the exact size and length you need. However, one could be made easily by anyone with a hobby lathe. You would probably need to add a bulkhead where the shaft exits the fuselage that has a bearing installed to support the shaft at that area. And the shaft would have to be tapered at the end so that a propeller drive hub could seat on it and then of course the very end threaded for the nut.
Kmot is offline
Old 01-30-2011, 05:16 AM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't image that it would worth the effort to make an extension of the prop shaft. You would just add a lot of weight in the rear of the plane. Best would be to use a lightweight engine I guess and mount it were it needs to be in order for the prop to clear the fuse. Cooling can be problematic with rear mounted engines so I guess you are better off the head sticking out in to the little airflow that there is.
Mr Cox is online now
Reply
Display Modes
