Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
Eflite T-34 to glow
Reply
Old 07-20-2011, 05:55 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Eflite T-34 to glow
Has anyone done this? I was thinking, I can get a bare fuse and tail, and put a glow and guts in it, and just swap wings when I want to fly on fuel. What would I need to do to beef up the fuse and seal it for a glow and what size would it take. I am thinking 4 stroker.
acdii is offline
Old 07-20-2011, 08:03 AM
mike early
mike early's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Eflite T-34 to glow
Saito .62 would be my choice.
A saito .40 would fly it though.
I usually cut a piece of plywood and epoxy it to the front of the fuse and mount the engine to it.
mike early is offline
Old 07-20-2011, 08:59 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What about the tank? Would I need to open up the floor where the battery goes to fit one in, or do they make tanks about the same size as the pakc, which is long, narrow and flat.
acdii is offline
Old 07-20-2011, 09:15 AM
mike early
mike early's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You wouldn't need a large tank. 4-strokes are pretty efficient. All sorts of shapes and sizes available. Probably would have to alter some of the internal bracing but weight wouldn't be much of a concern, so you could add wood to make it stronger than it was before. I've converted a few planes to glow and the fuel tank was never a big problem. Keep us posted and teach us all how it's done!
Old 07-20-2011, 09:42 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just looked up the parts, I can get the entire plane, minus the motor, and servos, for $199. If I get just the tail and fuse its $142. The wing is 108, so might just get the whole ARF instead.  Yeah, found my winter project!
acdii is offline
Old 07-20-2011, 01:08 PM
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well if i was to do that plane as a glowhere is what i would do:
1. set up for saito 62 with 8 ounce tank for normal to to much power
2. Eflight electric retracts small ones if off paved runway.
3. add some pilots
4. if want scale and engine inside cowl then two options saito 40 single or saito 60 twin if weight isnt a concern for ya.
for the 62 run a 13x8 APC or xoar
40 single run a Xoar 12x6 electric prop with 35% will spin it at 9,700-9,900 very scale set up
60 twin run a 14x6 Xoar
xoar props can be painted flat black and have the tips yellow.
airraptor is offline
Old 07-20-2011, 02:44 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh I didnt know they made twins that small. Definately something to look at. Now that would look awesome and sound really good too.
Oh retracts is something Ihave planned for the one Ihave now. If Iwere to swap wings I would only need one set of mains between the two birds.
acdii is offline
Old 07-21-2011, 09:42 AM
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.horizonhobby.com/Products...rodID=SAIE060T
Old 07-21-2011, 10:11 AM
mike early
mike early's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That twin would be cool as hell. But heavy. Expensive.
Old 07-21-2011, 01:09 PM
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes it is heavy but really cool sound.
Old 10-12-2011, 05:47 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well after 2 dead sticks yesterday with less than 8 minutes each pack, I decided to go forward with the glow conversion. My friend was flying his hobbystar clone with a 4 stroke in it, and that thing was a rocket, yet could float at slow speeds.  Made the 34 look anemic. I also found that with the glows going I cant hear the ESC whimper when the battery is about to go. I need to find out what motor he has and get one.
 My first dead stick I had made a low pass over the runway, still practicing those so that I can get my line ups right to practice touch and goes, and  just as it got 2/3rds down I heard the motor slow down, and I had to try to bring it around, missed the runway by 10 feet, but the soybeans made a nice catchers mitt.  The second one started whimpering before the timer hit the 8 minute mark, but I had some altitude and enough time left to bring it in for a safe nice landing.
This is the first time I had short flight times in this plane, no hard flying, no more than 3/4 throttle through most of the flight, had to do a couple bursts to avoid the other plane, and an aborted landing, but nothing more than in previous flights.  Each time the pack was pretty warm too. It wasn't as windy as it has been, and the temps were in the 70's, so not sure why the flights were so short.  I have had 12 minute flights with juice still left in the pack in this plane. I get up to 16 minutes in the Apprentice.
So in addition to building the TF P-51, which I started last night, I am going to convert the 34 to glow. 8 minute flights just aren't long enough when you are trying to practice landings.
acdii is offline
Old 11-02-2011, 06:05 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OOOH  http://www.horizonhobby.com/Products...FG14B%2882B%29
acdii is offline
Old 01-09-2012, 04:58 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright, picked up an OS 52 Surpass for it yesterday, going to start working on getting it converted tomorrow.  Need to see if the current motor mount I have will work for it, or if I need to find something else.  I put the motor up to the cowl and it looks like it will just clear the nose gear and will be completely inside the cowl.  The cowl has two huge openings so it looks like there will be plenty of air flow, plus a large opening where the gear protrudes for an exit.
acdii is offline
Old 01-11-2012, 11:18 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, if anyone is deciding to go glow on the Eflite T-34, beware that there is a lot of modification to do. I took mine apart last night to begin the conversion and after studying it very closely, I am reconsidering converting it.
First, the E motor attaches to a box under the cowl, along with the nose wheel . It sticks out a fair amount too. The internal structure of it is what is changing my mind. The floor under the canopy extends all the way into that box, and the sides of the battery try extend to the front and interlock with the sides of the box and floor. If I were to cut it, I would need to cut it at the exact same angles that it has now, then fit the firewall to whats left of the box, notching it to match originally, then epoxy it all back together. I would have to take off about 1 1/2" from it to make the cowl fit.
Downside, it would also move the nose gear back that same amount. I think doing that would make ground handling a pain.
I weighed the new motor, mount, tank, and RX battery and compared them to the e motor, ESC and battery pack, and they come out almost the same, the new motor slightly lighter.
Alternate way, which would give me the ability to convert it back to e power is to mount the motor on the existing box, and extend the cowl out 2 ".
What I don't know about that scenario is how much it would affect the location of the CG. The less structure I cut out, the less bracing I would need to add.
One other item I am concerned about, the mounting of the tank. In order for the tank center line to be at or below the carb, I would have to cut out the floor, and that would make the fuse weak in that area since again it is tied into the firewall.
I have some pictures I took, but cant find my iPhone cable at the moment to post them.
acdii is offline
Old 01-11-2012, 07:02 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gonna try again, it only lets me upload one image.
acdii is offline
Old 01-15-2012, 08:44 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After not being able to find a flat enough tank I decided not to do this conversion.  I would have to basically rebuild the forward half of the fuse to strengthen it enough for the 4 stroke, and there isn't enough room for a tank even if I remove the floor, the wing sits to far forward.  Considering how much this plane costs to replace is another deciding factor, just the fuse alone is over $100, and that doesn't include any hardware.
acdii is offline
Old 01-19-2012, 12:03 PM
Admiral052
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Darn it Acdii I was hoping to see this happen too. I have this plane and like the look and design but this is my first electric and I am used to glow. I was kinda hoping for the option to convert it. I understand what you are talking about with all the work needed.
Admiral052 is offline
Old 01-19-2012, 05:41 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Iknow how you feel. Here is a shot of the tank lined up on the Fuse showing how little room there is for it. This tank is actuallly the thinnest 12 ounce tank I could find.
acdii is offline
Old 01-21-2012, 01:34 PM
sharp333
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
12 oz tank is way too much for a 52 4 stroke. I use a 6 oz and it gives me about 12-15 min fligth
sharp333 is offline
Reply
Display Modes
