Falcon 120 help
Falcon 120 help
I have a falcon 120 from nitroplanes and I was wanting to do a dual EDF setup, I was wondering if dual 70mm running on a 6s
-Outside Diameter : 71mm
-Material:Carbon Fibre Reinforced Nylon (Whole Unit)
- Rotor DIameter : 68mm,4blades
-Max RPM:50000 RPM
- Motor Shaft : 3.0mm & 4.0mm
-Working Voltage : 11.1v - 22.2v (3 - 6S )
- Motors required :Inrunner & OutrunnerBrushless Motor2500 - 4300Kv
-Max RPM:50000 RPM
BC, CANADA
RE: Falcon 120 help
ORIGINAL: ckreef
This is a forum for converting an electric plane to glow power. You might get better responses in a different forum.
Maybe he wants a prop nitro nose?
