Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
Great Planes SU-31 3D + 30 size 4-stroke!
Reply
Old 11-30-2016, 04:17 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Great Planes SU-31 3D + 30 size 4-stroke!
I think that this is going to be my very first post here at RCU. So, Hello all!
So here we go. I am going to convert this Great Planes SU-31 3D into a glow plane.
The donor was a wreak from one of my buddies at the field. He exploded the left wing on a bad landing attempt. The picture below are after I glued all of the splinters back together.
Specs form the factory:
Wingspan: 41 in [1040mm]
Wing Area: 343 in2 [22.1dm2]
Weight: 27.5 31 oz [780 880g]
Wing Loading: 11.5 13 oz/ft2 [35 40g/dm2]
Length: 38 in [965mm]
Here is the current condition after quite a bit more restoration,(still with the electric power in this pic). I'm Still in the process of covering. Needs a little more detail.
My goal for this build is to put a .30 4 stroke. I am hunting for one right now on RCU market. I already bought a magnum XL FS30AR but im still trying to track down an OS or Saito. These are not easy to find.
ID:	2191838   Click image for larger version
badfrogg is offline
Old 11-30-2016, 06:24 PM
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice work!
From the size id say a 25-32 two cycle would be the best. A .30 four cycle may be a tad under powered and on the heavy side. All depends on the performance you expect when done.
So far though, very nice work!
Twin_Flyer is offline
Old 11-30-2016, 07:05 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it performs like this then I will be stoked.
I think I just scored a Saito FA-30 on the market, Fingers Crossed!
https://www.youtube.com/watch?v=pcVsQklNlCY
badfrogg is offline
Old 12-01-2016, 06:34 AM
rgburrill
rgburrill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't get my system to download the manual for this thing so you need to check this out for yourself. Small electric ARFs aren't known for handling the vibration levels of a fuel engine. especially a 4 stroke.
rgburrill is offline
Old 12-01-2016, 06:56 AM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know... that's what makes it interesting!
badfrogg is offline
Old 12-06-2016, 08:35 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look what just arrived. Thanks to a great member here answering to my want ad.
So now i need to figure out mounting.
Mark all of the center lines and cut away half of the original mount.
The piece that is left will act as a guide when i go to glue in the new mount,
ID:	2192499   Click image for larger version
ID:	2192500   Click image for larger version
badfrogg is offline
Old 12-06-2016, 08:49 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Making the new mount out of hobby ply.
It will extend beyond the firewall and tie into the pine wood block that the landing gear is mounted to.
Mounting the servo into the mount Why not...
Made some more weight saving cuts as well.
Ill get this mount glued in. Once that sets up I will cut the rest of the old motor mount out and then add new side pieces of plywood to brace against the firewall.
The tabs that I built into the mount will lock in to that side brace.
ID:	2192502   Click image for larger version
ID:	2192503   Click image for larger version
ID:	2192504   Click image for larger version
ID:	2192505   Click image for larger version
badfrogg is offline
Old 12-13-2016, 07:54 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decided to move the engine back 14mm (engine bolt spacing) to help balance the plane a bit.
Pretty much about to wrap it up.
Looking forward to a maiden this weekend!
ID:	2193387   Click image for larger version
ID:	2193388   Click image for larger version
badfrogg is offline
Old 12-21-2016, 07:37 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished!
https://www.youtube.com/watch?v=JBjNB6EjS0Q&t=133s Nothing like breaking in an engine in the air!
badfrogg is offline
Old 01-19-2017, 09:58 PM
badfrogg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Time for another Great Planes electric ARF to Saito power!
Scored this Super Stearman from a local guy. And I got another great deal on a Saito FA-30s form the RCU market.
badfrogg is offline
Old 01-20-2017, 05:55 AM
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice!
Should do well with that Saito!
Old 05-30-2017, 05:32 AM
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice idea for the motor mount conversion. I would have cut off the electric mount, installed a ply firewall and screwed on a motor mount, but yours looks better and is probably lighter, plus, as you say, the alignment is already correct. Great job!
I love the little four strokes. I have two Saito 30s and two OS 26s. They sound great, they are very light, and they are friendly little things to fire up. They start well, throttling is excellent, I can't understand why they are disappearing from the market.
Looking forward to the test flights.
Jim
buzzard bait is offline
