Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
49" Edge 540
Reply
Old 04-21-2010, 11:35 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 49" Edge 540
I am converting a Aeromax (ya ya ya I know) 49" Edge-540 to glow. I got it from good ol' cyradio on ebay. It arrived with some fuselage damage, I decided to repair it rather than hassle with sending it back. Hey, I knew the job was dangerous when I took it.
Anyway here are the specs;
49in EDGE-540 30E ARF
WINGSPAN: 49"(1245mm)
LENGTH: 46-1/2"(1180mm)
WING AREA: 450sq in(29sq dm)
WEIGHT: 2.4-2.65lbs (1100-1200g)
PROP: APC13x6.5-E (not included)
BATTERY: 2100-2500mAh LiPO 3-4S (not included)
MOTOR: E-Flite Power 10 / AXI 2814 or equivalent (not included)
ESC: >40A (not included)
I have a new Magnum 52 four stroke to power it with. I should be able to keep the weight under 4 pounds, this should make it 3D capable and give it nice verticle performance.
motoxxx996 is offline
Old 04-21-2010, 11:41 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
the pic did not show up on the first post for some reason.
Old 04-21-2010, 02:01 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
After fixing the damaged fuselage, I went through and re-braced the whole frame with 1/8"X1/4" balsa scraps and used ply at the firewall to strengthen it for the added weight and vibration that it will have. I also re-glued all of the joints and put epoxy in some choice locations.
Old 04-21-2010, 03:35 PM
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
you need to stay close to the electric weight to fly 3d good. if at 4 lbs it will not be a great 3d plane at all. even at 3 lbs will be a dog in 3d stuff. what does that magnum weight?
airraptor is offline
Old 04-21-2010, 10:16 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Displacement: 52ci (8.53cc)
Bore: 23mm
Stroke: 21mm
Practical RPM: 2,000 - 10,500
Weight: 15.7 oz
Exhaust thread size: M10 x 0.75
That is bad news for me, I put everything that is going in it into a plastic bag and weighed it, I will be under 4 pounds but way over 2.65 pounds. Oh well it is what it is I suppose, there is nothing I can cut out, I'm using all mini servos a micro reciever and a small lipo battery. I have the same motor in a plane that weighs 4 pounds 8oz and with a 13X4 prop spinning at 10,000 rpm it will climb verticle. So if nothing else I will have unlimited verticle performance in this plane weighing almost a full pound less.
Old 04-21-2010, 11:30 PM
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
yes it will climb good but hovering it and high alpha 3d will lack some. it will still be very fun to fly. that engine would do well in a larger electric 3d plane around the 3.5-4 lbs weight
Old 04-22-2010, 09:27 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Ya I get what your saying, I still want to try this motor in it just for fun, I can always swap it for something lighter later.
Old 04-27-2010, 12:38 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
The firewall is measured, next I will brace and epoxy it.
Old 04-29-2010, 12:09 PM
Mr67Stang
Mr67Stang's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
This is a nice project. I like it. Not every plane has to be a 3D machine
Mr67Stang is offline
Old 04-29-2010, 08:33 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Thanks, I just hope it is fun to fly.
Here are some pictures of the progress, for some reason I can only attach one pic per reply.
Old 04-29-2010, 08:34 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
one more picture
Old 04-29-2010, 08:37 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
and another
Old 04-30-2010, 08:23 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
I got the throttle servo and the fuel tank in.
Old 05-09-2010, 11:39 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Here she is moments before the maiden flight. I left the cowl off for the first test flights to keep it cooler and so that I can inspect the motor mount for vibration damage after the intial flights.
Old 05-09-2010, 12:20 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Here is a couple of links to videos of the first flight.
http://www.youtube.com/watch?v=cq72MxQzYL0
http://www.youtube.com/watch?v=fhXH5QFxMGs
It has a very fast roll rate but they were out of frame on the video. I put it into a throttle off nose up stall and it recoveded very nice even though the CG was very far back. Vertical performance was also very nice and it should be even better once I remove the break in prop. The wind was picking up fast so I only got in two flights, I can't wait to fly it again, with a little fine tuning it looks like it will be a lot of fun.
Old 05-09-2010, 05:08 PM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
All of the final details are finished and it's all balanced.
Old 05-10-2010, 01:53 PM
Mr67Stang
Mr67Stang's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Looked a little floaty landing so I think you got the weight right. Congrats on a successful conversion from lecky perversion
Old 02-04-2011, 07:34 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
I have sevral hours of flight time on this plane now, it is a LOT of fun to fly. Just for kicks I put a GPS in it, I recorded a top speed of 82MPH, 9 miles of flight in about nine and a half minutes and a max altitude of just over 500'
Old 02-07-2011, 08:12 PM
furn1593
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
curious about the final weight / prop selection / battery mounting location (lipo and VR?).. could post a pic of the innards if you have some time.
furn1593 is offline
Old 02-10-2011, 06:26 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Sure I will weigh it later today and check the prop size I cannot remember right now. I have a 2000mah 2s lipo stuffed wayyyyy back in the tail. I will take some pics of the inside and post them.
Old 02-11-2011, 02:51 AM
mainegold
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Nice conversion. I am also interested in interior pics.
It must suck to have to fly near those light poles, huh?
mainegold is offline
Old 02-12-2011, 11:23 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
Here is the interior, not much to see, the battery is stuffed all the way in the tail behind the green foam. The prop is a 12X4 or 12X6 I would have to pull the spinner off to see the pitch, but I know for sure it is 12".
Old 02-12-2011, 11:30 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
More pics
Old 02-12-2011, 11:33 AM
motoxxx996
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
It wont let me attach more than one pic at a time.
Old 02-12-2011, 07:05 PM
furn1593
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 49
you running the 2 cell lipo thru a voltage regulator? What are the specs on the lipo.. mah/C rating
furn1593 is offline
Reply
Display Modes
