Looking to convert this Cosmos!
CA
Both me and my son won Cosmos's in the local raffles during our monthly meeting. Almost a year apart.
http://www.cermark.com/products/Cerm...ctric-ARF.html
We would like to make them glow for more fun. What would be a good size engine for them without over doing it? The site recommends a CEM-2812-840 kv Outrunner Brushles Motor.
skeeter
skeeter
RE: Looking to convert this Cosmos!
At less than 1 lbs advertized weight and 285sq in wing area it will not take much engine to get this flying. I bet an old Cox .051 TD would make it fly but not 3D. The OS .10 LA would give this plane the required power but I would be concerned about how fragile this plane might be when subject to the vibration. In the pictures the wing looks like it was built up with minimum structure and weight in mind. I am not saying it can't be done by any means but it will be challenging.
My Feedback: (66)
the best engine for power and weight is the novel .074 if you can find one.
Stang a td.051, or even a norvel .061 would be hard pressed to fly it with that thick wing.
you are better off finding another plane better suited for a glow conversion.
ORIGINAL: airraptor
CA
I have an old OS Max .15 in the crockpot cleaning up. I was thinking if it runs good use that! Think it might be a wee bit too much though. Haven't looked closely at the frame to see what kind of work it would need to handle glow.
skeeter
skeeter
Okay, lets look at the specs; 31", 285 sq inch area, and 14.5oz. This should fly just fine with a good .049-.061 engine. A Norvel .074 will pull it vertical and an OS .15 will turn it into a brick...
Save the .15 engine for something around 26oz and 350 sq inch, that's my advice...
