Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
Reload this Page >
How sensitive is intake mani length on a little 4 stroke?
Old 04-29-2011, 05:37 PM
tkg
Default RE: How sensitive is intake mani length on a little 4 stroke?
The $5 words for tuning an intake are Helmholtz resonance.
Using the basic formulas you can tune the intake ( make the intake tract resonate) to certain frequency. If the tuned freq matches the engine rpm you get a positive, supercharger effect and gain power. Operating out out of the freq range you get a 0 increase or an actual decrease in power.
Old 04-30-2011, 02:36 PM
NorfolknGood
I made an intake manifold for my GX31 from a piece of steel from a kids bicycle it worked a treat.
Old 05-01-2011, 10:04 AM
av8tor1977
av8tor1977's Avatar
Looks good and I'm sure it works fine.
The only difference is when I used a plywood spacer, I gave mine two coats of epoxy thinned with a little alcohol to seal it. Probably not necessary...
AV8TOR
Old 05-01-2011, 11:25 AM
NorfolknGood
Yes I should have explained I ran thin cyno all over the ply.
Old 05-01-2011, 11:49 AM
gkamysz
My Feedback: (19)
gkamysz's Avatar
There are two tuning phenomena. Helmholtz and dynamic flow.
