CDI gr8flyer55
Reply
Old 12-15-2012, 12:02 PM
  #1051
Gompy
Gompy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CDI gr8flyer55
I just programmed a new PIC-version, 40 degrees BTDC and a straight line of 24 degrees BTDC.
Within the range of 2000 till 10,000 rpm the timing will be at 10,000 rpm 12 degrees.
For a normal 2 stroke Homelite this is a very good table with good values.
BUT, thats not wat I have programmed and thats the problem.
It look good on paper, but into the field it's not good.
First I was thinking it was the magneticfeeld, at high speed the feeld moves and will be smaller.
Now I use a optosensor with a window of 5 degrees, very small, zo there is no 20 or more degrees magnetic window like the hallsensor have.
It's no problem to use this software, but you have to program only straight lines and use twostroke engines
Gompy is offline
Old 12-15-2012, 12:13 PM
  #1052
Nav-Aids
Nav-Aids's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL
Nav-Aids is offline
Old 12-16-2012, 08:59 AM
  #1053
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ray, have you been in contact with Jake about the problems with the excel sheet and the fixes you have done?
Seems he is now to busy with his other projects. I am about to program my first chip with your corrections, although I think the timing problems haven't been addressed as of this time. Is there anything really potentially wrong using my curves with the current "fixed" F1 version? Or should I hold off until you take a look at the file for any problems?
I can just do a static test first which I always do anyway, but if there's nothing really wrong, I'll do my actual engine tests today to check functional switches, starting and top end timing etc.
John
gr8flyer55 is offline
Old 12-16-2012, 09:57 AM
  #1054
Nav-Aids
Nav-Aids's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gr8flyer55
John
I have been in touch with Jake early last weekand he is in the middle of exams right now, exams should be finished by now or byWednesday at the latest, that's how mine were. The only thing I fixed were problems with the spreadsheets themselves, from what I saw some of the values weren't being copied properly. As for the 'C' code itself, that remains unchanged but, the timing values should be what is selected now. Some problems only appeared in Excel 2003 and some were in both. In your case you were using Excel2007/2010 so there shouldn't be anything code wise that has changed for you so go nuts and let me know how it goes. Please note that only curve-1 is copied to the clipboard, I could not remember if just cuvre-1 got copied or both curve-1 and curve-2 got copied. I have to build a Gompy Timing Light right now.
Cheers
Ray
Nav-Aids is offline
Old 12-16-2012, 12:29 PM
  #1055
Gompy
Gompy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Again some movies to show wat happens with the timing
Curve 1 at 11,500 rpm ATDC
[youtube]http://www.youtube.com/watch?v=rH3-p_cSizs[/youtube]
Curve 2 at 8350 rpm ATDC
[youtube]http://www.youtube.com/watch?v=_Q-UcRnOvo0[/youtube]
Setupfiles
ID:	1830840   Click image for larger version
File Type: txt
Gompy is offline
Old 12-16-2012, 02:46 PM
  #1056
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I program a curve to either table and save it, then reload it later, it works great. Only the copy command from table one to table two is at fault. Otherwise, I ran an engine with it today and it follows the programmed curve exactly to the degrees of the program. Don't know what else to say. I can't duplicate the timing change problem.
John
Old 12-16-2012, 03:04 PM
  #1057
Gompy
Gompy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Follow the wave is not follow the curve, thats the differens.
I copy only one table into the code, I copy both tables to the code, I copy the complete code, I edit by hand and it's allways the same......wrong.
I don't know a other way to show wat is wrong, movies aren't problably not enough.
Have fun with the code, but don't complain if some one blow his engine and thye cost are yours.
Gompy is offline
Old 12-16-2012, 03:50 PM
  #1058
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am the only one testing it on an engine. My engine won't go past 7500 rpm so I don't have the problem. If its bad software, it's bad software. Not a problem. What I use in my planes was written by Nyemi. Never a problem. In fact, yesterday we flew one of my ignitions with Nyemi's software in a $7,000 airplane. Perfect performance all around. MSD works well on the DA 60 in that plane and some top contest flyers are now asking to try it. It's all I probably would ever need, but Jake's would be nice when it is working correctly I think.
When these problems are worked out, we will test it in my friend's plane.
The features it has make it desirable, not the problems. We were off to a good start just like last time though there are problems. I think it's all fixable though. I'm not afraid to do engine testing myself. I have nothing to lose, my engines cost me nothing other than my time.
John
Old 12-16-2012, 04:05 PM
  #1059
Gompy
Gompy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is the monkey with the banana......Nyemi's software.
I'm done with it.
Gompy is offline
Old 12-18-2012, 12:42 PM
  #1060
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I remember something about some type of NET file that had to be updated to get things working..anyone remember what the file was?
I used to have problems until I updated them but can't remember what the name of the files were..Microsoft Netsomething..
John
Old 12-18-2012, 01:14 PM
  #1061
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just remembered what it was. Net Framework.
If these files are not up to date, it says on microsoft's website, that all kinds of problems will result from running Visual Basic routines etc. Everything I can think of problem wise with the spreadsheet is all dependent on Net Framework. I'm hoping this is a solution to the wrong data being copied to the wrong cells in Excel. Mine was updated last year when they announced the update fixed numerous complaints in Microsoft applications such as Excel. Hope this is it. There is nothing else that could be machine specific as this problem.
John
Old 12-18-2012, 02:08 PM
  #1062
bluejets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I remember correctly, one had to install a particular version of microsoft netframework in order for the monitor program to work.
This was on the old 16F628A timer with the control software. That part worked very well.
Might have been version 3.5 or 4.
bluejets is offline
  #1063
Muciek
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's Netframework
EDit: sorry I was late with this answer. Didnt see other one's
Muciek is offline
Old 12-18-2012, 09:22 PM
  #1064
Nav-Aids
Nav-Aids's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The .Net Framework is not needed for the spreadsheet, it doesn't use it. Mind youthe Office updates and service packscan't hurt.
Ray
Nav-Aids is offline
Old 12-30-2012, 06:50 PM
  #1065
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ray, the fixes you made on the excel sheet seem to work good. There are few if any problems in the software except the rpm limitations. So, if it is used on a regular gas engine in the 7,000-9,000 rpm range it should now be fine.
Is there anyone else testing the software, programming curves etc. ?
John
Old 12-30-2012, 06:54 PM
  #1066
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If Jake can post the "fixed" sheets on the website we can move on to the next version. I have version 1 working fairly well running my test engine just fine, easy starts, curve switching works, and the ignition kill is also working, without RFI.
John
Old 12-31-2012, 01:07 AM
  #1067
bluejets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John
I started to but ran into more strife than one can imagine with the Mplab throwing up errors. Tried uninstalling and re-installing various versions without much success. I can manage to get a hex file out of one install now but it would be anyones guess if it is any good given the errors the Mplab throws up. Spent 3 days on it now , just a waste of time really. Even tried a fresh windowsXP install but nope.
Nothing to do with Jakes software, it does it with other proven c code also. Sent a message to Microchip but doubt will get much sense from them given i'm running on WindowsXP.
bluejets is offline
Old 12-31-2012, 02:48 AM
  #1068
Gompy
Gompy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rename to hex, 30.000 rpm / 30 degrees BTDC.
Happy NewYear.
File Type: txt
Gompy is offline
Old 12-31-2012, 03:23 PM
  #1069
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeff, did you get all the Microchip files in order? I had no problems after downloading the updated device files for the XC8 compiler. I think it was suggested a few pages back about them.
Haven't had a chance to test Rob's hex file yet, but I think he must have gotten his programming figured out or he wouldn't have posted the file.
John
Old 12-31-2012, 03:27 PM
  #1070
nyemi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi everyone
Happy New Year..
Hungarian
Sikerekben gazdag, Boldog Új Évet kívánok mindenkinek.
Üdvözlettel nyemi
nyemi is offline
Old 12-31-2012, 04:01 PM
  #1071
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Nyemi !!
Happy New Year !!!
I am hoping to get all the problems behind us in the new year.
There are a few new projects coming to go with the ones we have completed. A nice timing light, some optical switching devices, and maybe even a more efficient, simpler, and smaller ignition for the new smaller sized planes. I'm working on the size, then the power requirements. Possibly going as low as 3.7 volts from a single LiPo cell for power. I know it's already been done commercially, we need it done cheaper.
Hoping it is going to be a good year.
John
Old 12-31-2012, 05:14 PM
  #1072
bluejets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John
No, no luck what-so-ever John.
So I did like you suggested just went right back to page 30 but did not see any reference to xc8 compiler.
You mention update device files for the compiler, where did you get these. A search on Microchip returns maybe 30,000 results.
I might try and download latest Mplab and xc8 again, format the drive (again) and see if anything comes up differently.
Happy New Year....
bluejets is offline
Old 12-31-2012, 09:35 PM
  #1073
dinoslmn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I wish to all of you a Happy New Year, healthfulness, happiness, good flyings (and landings) and....softwares without bugs
Dino,
dinoslmn is offline
Old 01-01-2013, 07:25 AM
  #1074
stewccm500
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi, all at rc univers. can anyone help with a cdi problem ? i have some understanding of electronics, but i need some more detailed help. i have seen that the rc world of clever people can make a cdi run very eficiently from a small dc supply. all i need is the power supply part of this to run an old british scrambler bike (ccm500 made in 1979, origional cdi ran from small alternator, rectifyed to 3-10 volt dc, powered an inifficent socillator to charge a capacitor and give the spark. timing is by a lucas rita magnetic pick up on cam shaft, shape and size of blade, coil inductance etc automaticly gives very good timig advance/ ret, triggering a sensitive thyristor for spark) it only just worked ! kick over speed is very slow (11/1 comp ratio, castor oil in winter !) a similar better syestem was avalible as an option with re-chargeable batteres, but this was all in a very big box with a ht lead comming out of it. i have tryed improving the origional system but to buy and modify a modern cdi box is probably the way to go.
thanks stew.
stewccm500 is offline
Old 01-01-2013, 08:22 AM
  #1075
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Stew.
Seems like you are in need of a CDI upgrade for your system. Our CDI is probably adaptable to your system with some minor changes made to it. Ours requires a dedicated power supply that is regulated to 5 volts. Your supply needs to at least supply the initial voltage from the alternator since there was no mention of it having a battery. Filtering it thru a large capacitor to retain voltage for startup is a requirement unless you make up a power switching arrangement with a small battery somewhere in the setup. Ours takes a voltage constant for the timing chip to initialize and be stabilized befor it can produce the first spark. The issue of a magnetic pickup can be worked out. Ours uses a hall sensor and a South Pole magnet for the trigger.
Once you work out those few steps, you could probably use a system like ours.
Hope this helps. If not, I'm sure others can offer some suggestions to get your system figured out.
John
Reply
Display Modes
