Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
Reload this Page >
Stihl 65cc "Four Mix" four stroke engine
Old 07-15-2012, 01:57 PM
Scota4570
Default Stihl 65cc "Four Mix" four stroke engine
The airplane is a Bridi big bee. The prop is a Vess 23A. Sounds like a flying lawnmower.
http://scotplanes.shutterfly.com/pictures
Sorry had to fix the link.
Old 07-16-2012, 10:20 AM
av8tor1977
av8tor1977's Avatar
Default RE: Stihl 65cc "Four Mix" four stroke engine
VERY nice. Glad you are finally getting some good use out of that engine. It sounds great!!
Darn it, now you've got my (already high) interest increased to get one flying myself! I sold two of the 32cc Stihl four strokes to guys and they are quite happy with them. I have a 36cc that I saved for myself and am just waiting on new rings to finish it up. Plus I have a couple more 65cc four strokes to do. Too many projects!!
Anyway, looks great. Like you said; a lot of power too, but that sound..... I can just see/hear one in a Fokker D7, or another oldie favorite of mine, an AVRO Triplane!!
Note: Your title is wrong. It is a Stihl 65cc "Four Mix" four stroke engine; not Echo.
AV8TOR
Old 07-16-2012, 08:06 PM
Scota4570
It would do well on a D7. The exhaust is on the correct side. Making a scale exhaust pipe would be no big deal. I would probably leave the magneto. The flywheel is relatively tiny. The weird 11mm prop hub thread is the only possible issue. I re-threaded mine to 10mm. The straight non tapered crank works fine. The prop hub was easier to make accurate because of that.
Old 11-07-2012, 04:30 AM
Rudolph Hart
Rudolph Hart's Avatar
I've never heard of these engines but after hearing your one fly would look at putting one in a decathlon of the right size any problems?? converting one to fly..
Old 11-07-2012, 02:15 PM
SkyPilot101
av8tor, How did your 36 cc four mix turn out? It would be interesting to see & note differences from the 32 cc job's
Old 11-07-2012, 05:26 PM
av8tor1977
av8tor1977's Avatar
I haven't had time to finish it up, but as great as the 32cc engines ran, I am sure the 36 will be a good runner as well. My 36 doesn't lack much to be ready to run, but I've just been too busy...
AV8TOR
Old 12-22-2015, 07:23 AM
kfla
Scota4570, I'm in need of a prop adapter for a stihl 65cc engine Any interest in selling me one? Thanks Kevin
