Best place to buy Walbro carb kits..
Reply
Old 10-18-2012, 09:58 AM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best place to buy Walbro carb kits..
I wonder if anyone had a good recommendation for an online source for Walbro carb parts, I need a few diaphragms, some have dried up on the planes.
foodstick is offline
Old 10-18-2012, 05:38 PM
Scota4570
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best place to buy Walbro carb kits..
find a local old time saw shop that will sell you just what you need. Most of the stuff in the rebuild kits is not needed.
Scota4570 is offline
Old 10-18-2012, 07:06 PM
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Generally all that is needed is the regulator diaphragm, and I buy them by the "10 pack", wherever I can find them online cheap. Usually most of the other gaskets can be re-used.
AV8TOR
av8tor1977 is offline
Old 10-19-2012, 10:18 AM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I might be interested in the 10 packs online, I have multiples of the same engines. I haven't ran across that before.. any chance you recall a vendor?
I will search some more, but so far I had found single kits, and was looking for the diaphragms..
addendum
ok, I did some searching and found the multi pack kits, they appear to have a different part number on them than the carb body, will the part number be on the old diaphragm when I pull it out? or is there a cross reference chart for the parts numbers used in each carb?
Any help is much appreciated...I don't think I have a single old diaphragm laying around to look at... I will take one apart when I get a chance...and see.
Old 10-19-2012, 10:51 AM
Tidnab
Tidnab's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gizmomotors has 10 packs for $20 http://www.gizmomotors.com/index.php...mart&Itemid=56
Tidnab is offline
Old 10-19-2012, 11:07 AM
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The diaphragm is the same for all WT series Walbro carbs, and many others. (The link above shows which models/series have the same diaphragm in common.)
AV8TOR
Old 10-19-2012, 08:04 PM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Common part [X(] awesome, that works for me !
Old 10-19-2012, 10:10 PM
rangerfredbob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the only difference is the carbs with the primer bulb on the regulator side have the pass through port on the gasket, other than that all the WA and WT regulator diaphragms are the same.
rangerfredbob is offline
Old 10-20-2012, 02:19 PM
Nosedragger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
there are 2 diaphragms used in WT,WA
pump diaphragms and metering diaphragm, no such thing as a regulator diaphragm in these carbs.
2 bucks each? I get them for half that.
Nosedragger is offline
Old 10-21-2012, 12:49 AM
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most people call the metering diaphragm a regulator diaphragm here in the forums. Where do you buy them?
AV8TOR
Old 10-21-2012, 03:41 AM
Tidnab
Tidnab's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are the ones you get for half the price of the ones in the link above,Walbro ones or aftermarket ?I've found that the aftermarket ones don't last as long.
Tidnab is offline
Old 10-21-2012, 06:01 AM
Nosedragger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The thing is if you do a search on regulator diaphragm it won't turn up as many results as if you used metering diaphragm.
Old 10-21-2012, 11:16 AM
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good point.
AV8TOR
Old 11-08-2012, 07:24 PM
Flathead
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up 10 diaphragms from fosto tools on E-BAY for $11.99 and they pay shipping check it out "FLATHEAD"
Correction: fausto_tools
- Moderator
Flathead is offline
Old 11-08-2012, 09:38 PM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ordered a set
Reply
Display Modes
