Echo 30.1 Chainsaw hub?
MI
I'm starting to convert a 30.1CC Echo chainsaw engine. My question is does the prop hub HAVE to thread into the crankshaft? I'm thinking about machining a prop hub that bolts to the flywheel using the starter dog holes already there. Seems like Zenoah and Fuji use this concept already.
Jeff
Jeff
RE: Echo 30.1 Chainsaw hub?
Most of the prop drivers are setup to just fit over the crankshaft. They then use a bolt through the center to hold it on. Usually they have woodruff keys in there too. Bolting it on is fine, if you can keep it centered OK.
