Man, it's dead in here! Chinese scourge?
Here's another setup of mine on a much modified Zenoah 26cc. It shows the sensor mounting with a homemade bracket. (The sensor has the leads folded back, and then is epoxied into a carbon fiber or aluminum tube in this case.) If you are unsure or uncomfortable about making a round tube sensor setup like this, try here:
http://www.ch-ignitions.com/index.ph...roller=product
AV8TOR
AV8TOR
Thanks. My prob is that I have ZERO machining resources whatsoever. I would have to have someone make the prop hub for me and it be for EI. I think BCMA engines years ago converted the Homie 33's to EI but they are long gone.
It may have to be a mag engine......I have all the parts for that.
